John___Angela
Feb 14, 2014Explorer
If you are considering a little more permanent type setup you can also consider low wattage baseboard heaters. These are 500 watts, thermostat, mounted (no falling over) and kinda blend in. No fan so no noise but you will need 3 or 4 to make the heat even. We went this approach as well as underfloor heating (under laminate) which makes it easy on the feet. One of the posters on here (Piano Tuner) uses an after market heated carpet approach which he really likes. I guess my point is there are alternatives to the little heaters with fans. Good luck in your search and happy trails.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
