I know, I know.....that 'new' smell & feeling
It will fade but not as quickly as the depreciation on that new rig.
And you will be living in it......so what are your plans when you have to take it back to dealer for warranty and they keep it for weeks and then you find out they haven't done anything yet and keep it for more weeks etc......
As suggested look at used rigs......they normally have the bugs worked out and are usually 'only driven to CG on weekends 5X a year'
Most of the CG's we have been to had 'full time residents' for various reasons.
Keep your site clean, uncluttered, be friendly/wave and don't be afraid to ask one of them neighbors for help. Remember that not only is that site part of your 'home' but the entire CG is YOUR neighborhood, a very small close one.
Get a good quality hose for hooking up to city water connection.
Keep and use occasionally, water in your fresh water tank for those unforeseen incidents (no water at CG)
Get an adjustable water pressure regulator...Watts
Never leave your black tank drain valve open.......dump black tank only when it is full/almost full (High liquid level/weight of liquids will carry the stuff out when dumping). After dumping...flush/rinse tank then add couple gallons water back into tank (2 toilet bowl flushes). Then dump grey tank to flush sewer hose.
Get to know your rig........ask questions when you are perplexed, don't know or are unsure.
Good luck on the next phase in your life.
