MagillaGorilla's avatar
Mar 31, 2015
Full Timing in a Gasser
It seems to be that the high percentage of full timers have DPs. Depending on how you live/travel the DP may or may not be the right choice.
The DP is considerably more expensive to buy, maintain and fill up. So to me you need to be mobile in order to justify it.
So why is it that more people, that stay put or just snowbird, don't buy gassers? What am I missing here?
To me it just seems that if you stay put all winter in one campground and then move to another one up north later in the year, that a gasser would be fine. I mean if you are just putting 3500 miles a year on it, what the point of the DP?
What am I missing? I'm sure I'm missing something here.
  • Up until about 2000 gas engines simply did not have the oomph to be good for a 22,500 pound RV. The advent of V-10 motors changed that.
  • If you have ridden in a DP you have the answer - the ride. Plus, if you are out west, climbing & coming down mountain passes, the exhaust brake just walks you down the pass so easily - again it contributes to the ride.
    Next we have carrying capacity - - most DPs have a larger CCC - we had over 5000 lbs available when we started, plus big bays that are open clear across the rig.
    Then there is the fact that the engine is in the back, so it is quite and you can listen to music, talk, all without that engine between the two of you.
    As to maintenance costs - yes it is more, but the interval in between is longer. If we spent all of our time in the midwest or east, then a gasser would do fine, but we cross the Rockies & Cascades/Sierras at least twice each year - usually more than that as we wonder around for the summer.
    Barb
  • Dealers get more commission on sales. What you drive or live in depends on what you can afford.
  • Executive wrote:
    Maybe you should ask this in the Full Timing Forum..:h..
    Is this not the full time forum?
  • :S..Senior moment..:W
    For us, we don't sit, we USE ours...15,000 miles last year..but the DP has more options, AquaHot Air Leveling, quieter too. Genset is in the FRONT so if you run it while you're sleeping you forget it's on....Dennis
  • I know quite few fulltimers with gassers. Some travel frequently while others stay put for months or even years at a time. I have no idea what the ratio is of gassers to DP's among fulltimers, but I do agree that DP's seem to be favored by the frequent travelers at least. We spend 9-10 months a year moving about in our 34' gasser, with stays of up to a month in locations we really like. The rest of the time we're at our lakeside cottage in upstate NY, although even then we typically continue to live in the coach for the most part.
