Jim-Linda
May 06, 2016Explorer II
janegowest wrote:RVcrazy wrote:
First of all, Cameo is a good brand...if in good condition. We use our heat pump most of the time. We switch to propane on nights when it is forecast to be below 45, even though some push it to 40. We don't like needing to mess with propane any more than we need to. Only the propane furnace will keep the warm air circulating in your water storage area. Our Hitchhiker furnace will automatically switch from heat pump to propane when the heat pump can't keep up if the propane is turned on (4 degree drop). I don't know if Cameo's works that way.
I believe it does. Why do you not like "needing to mess with the propane?"
Not the poster, but, depending what RV you get, consider.... after dark, raining, cold, propane tank goes empty, if you have two tanks, you did not turn the valve "on" on one. If MH and only one tank, you are out of propane. Now, do you go out in the rain and take tank(s) to be filled, or just turn on heat pump... your call.
Jim
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
