pianotuna wrote:
Hi harold,
You know very well my stance on the "cheap heat (NOT)" system. Too bad you choose to NOT share your extensive factual knowledge and real life experience of the system with others. I share it with thiose that need the information.
I have done more than one "back yard" experiment to show how many watts are needed to heat a class C. Where are your results? I do not doo back yard experiments, I do real life traveling all over north and central America.
My needs are pretty much identical with anyone who uses their RV in extreme cold. You do not do that, and it is great that you don't have to, because the system might just fall short of the needs. You must also be psysic. How is it that you know where I may or may not be?
For example last night at 1 a.m. the campground power went off. First my inverter picked up the load, then after that the furnace cut in.
It was -23 C (-9.4 f) outside. That would be enough to freeze up the entire rv quite quickly, if I had no "fail over" in place. Because I do, I slept right through the night.
[COLOR=]So did I. Use your psysic powers to figure out where I am.
Hint; The outside temp is 41C.
I know your stance, you have stated it in several other threads you have interupted and I do not care about your stance.
I share my experiences with those interested by PM or e-mail to avoid those that seem to enjoy disrupting discussions with no pertinent information.
You have no need for that information.
I will give you this much: The system paid for itself within three years and it has been used in temperatures as low as -14F in Whitehorse. In your metric world that would be -25.555556 if I did the conversion correctly. Not extreme but chilly.
Its wonderful that you system meets your needs, mine does the same for me.
One thng that is apparent is that those who think they know it all about the system are a hindrence to to those of us that do and have installed many and personaly used it. I have and will assisted anyone with choosing the configuration that suits their individual needs.
I will banty with you no longer. You have no useful information. :B
