LMHS
Oct 03, 2022Explorer II
Get a waterbed heater and put it on the bottom against the plastic tank. They are made to not melt vinyl so it will be safe for the plastic tank. I would suggest that you use a layer of reflectix against the tank and then use a couple layers of 2" rigid house foam (the colder it gets, the more insulation you will need). They make a special glue just for "foamboard" that you can find at Home Depot, amongst other places. This is what we did with a cistern for the spring that was next to our pump house. We used 4" of foam in the Southern Appalachians which was probably overkill for our area.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
