2PawsRiver's avatar
2PawsRiver
Iron in Water
Could be a stupid question but......in Michigan well water tends to have a lot of iron in it. I think most campgrounds are rural and tend to have well water. When you hook up to a water source is there a way to keep that water separate from your tank, or does the water go into the fresh water tank and fill the tank as water is used from it.
If the water goes to the tank has anybody made a water filter to filter water from the source to the tanks....hope that made sense.
  • I always use a charcoal water filter at the spigot in addition to our in rig water filtration system. When we were in MN a couple of years ago, I noticed our water pressure dropping. It turned out the spigot charcoal filter was totally plugged with iron. However, it had done its job as my in house filter remained clean and the water was clear. I write the date on the filter when I install it and change them at least every 90 days. I change our in house filter every 6 months.
    Any water going into the tank also is run though this filter.
  • My understanding is that MOST RVs have separate inlet for filling the tank and for direct water hookup from shore. In other words, if you have a hose running from a campground faucet to your RV, it will NOT fill your tank.
    If iron is a concern, there are filters designed just to deal with that. Spend some time at:
    https://www.rvwaterfilterstore.com/
