Cmccain13's avatar
Cmccain13
Low Of 1 Degree!!!
Ok so disclaimer I am from Texas and I am not used to cold temps like this. its not going to get above freezing Sunday till Wednesday (its now Thursday) on Monday it will not get above 15 degrees and a low of 1 degree. I am not in a 4 seasons rig I'm in a Class C 2021. SO how worried should I be that **** is gonna freeze and break on me? I will be of course in the rig the full time. We have a space heater that helps but its a pretty weak one. Any help will be appreciated.
  • valhalla360 wrote:
    Just convert to metric...1 C and it's not an issue (just kidding)
    Where are you in Texas and is there anything stopping you from moving?
    We are down in the RGV and our worst day is projected to be around 30F. Even up by Corpus Christie the worst is only around 23F for the worst low. (check the weather maps, it might make sense to head east or west rather than south)
    As a full timer, my first choice would be to get to a warmer area.
    Yes, 1F is challenging in an RV. If you can't move:
    - Fill the Fresh Water tank and disconnect the hose.
    - Assuming you are on a full hookup, drain the tanks and leave the valves open just before the first freeze. Try to limit water usage if you can as the waste hose will still freeze up.
    - If the water system is in an underbelly compartment consider putting a work light with a 75w bulb inside (be careful that it doesn't rest against anything that could catch fire).
    - Open the cabinet doors around any water pipes, so interior heat can get in.
    - Fill the propane tanks and plan on where you are going to refill them (We got caught in -5F for a few days one year and we were going thru a 30lb tank per day...the park wound up restricting propane fills to park residents)
    - If you have an electric heater, that can help. (during that time we were down to -5F, the furnace running full time and a space heater and we were still only up to the 50F's inside).
    - If you don't already have it, go to home depot and pick up some reflectics (it's silver backed bubble wrap insulation). Then fit that to the windows and hatches to help trap heat.
    Plan on a few miserable days.
    I'm really only worried about the tanks and the pipes. Do you think putting some anti freeze down the tanks? It's only gonna be bad for like 36 hours. Also I was thinking about pulling in the slide outs to make the space smaller.
  • RV=recreational vehicle. Personally I find little recreation that I like when the weather is really cold. I start up the engine and leave.
  • Just convert to metric...1 C and it's not an issue (just kidding)
  • I'd be worried. Move the space heater to be near pipes on the basement and run the furnace. Keep your water heater on.
    That is some serious cold.
  • If you are hooked to water, fill your water tank and then unhook. If your furnace is propane then make sure you have plenty, close your dump valves. One thing to check is the status of the automotive AC/heat setting. You want to make sure it’s set to recirc instead of fresh air. This can be a big source for cold air entering the mh. Unless you use the front seats while parked, consider blocking off the cab so you have less area to heat. Don’t use the propane stove or oven for heat as it will create a lot of moisture. Be safe.
