ItsyRV
Sep 01, 2019Explorer
Sounds like your situation isn't ideal for a DIY solution.
The only DIY possibility remaining that I can think of is if you call one of the portable sanitation service (porta pottie peopel) companies and see if they have the large ground waster storage tanks. They are those huge 300+ gallon rectangle tanks you see at fairs and events connected to all the porta-potties. You use it, call them when full, they come pump it out and keep doing that until you are finished and have them pick the whole thing up.
Another is of course the holding tank services that come to you with their service trucks. They clean the tanks with their pump and vacuum tank truck. They usually don't need anything but access to your unit.
Pretty much the things you are doing with your limitations is all you can really do. So it's get a bigger waste tank or call in the pros with their tanks.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
