punomatic
Jan 15, 2016Explorer
Old-Biscuit wrote:
Sounds like Movievision SLIDE Bar Switch is NOT making positive contact
Never have liked a slide switch. A little to far this way, not far enough that way.......ARRGH!
Could also just be loose connections on coax cables to the Movievision or out of it to TVs
X2 I had a problem with snowy picture in the bedroom. I finally traced it to a bad splitter. Get good quality components at Radio Shack or some such.
Can you bypass the slide switch with a short piece of cable and some fittings to see if that helps? If it does, you need a new AB switch. Good luck.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
