Darian - I got the feeling you're thinking about this because you think it's going to be cheap living, and it might be after you get everything in, but to do that, depending on how far electricity has to be run, I think you're looking at an easy $25,000.
We just put in electricity and it only had to be run from across the street and the cost was about $7,000 for the local electrical company to set one pole and the contactor to hook up the meter base and two 50A outlets. Also put in water by hooking into the neighbor's well across the street. I had a free backhoe and operator to use, just had to pay for diesel.
Call:
1. A well drilling contractor
2. Your local power company, ask how close power is and rough cost to get to your property.
3. Call a local electrical contractor, ask them once the electric company drops power to your property, how much it will cost to run power to the meter base and install 100A service to power a trailer house.
4. Call a cement contractor ask them cost to put in a pad.
5. Do you need a driveway and a culvert?
6. Call a licensed contractor for a septic system estimate - you'll also have to get a perk test done to see if some authority will give you a septic tank permit. You'll have to hire a backhoe to dig the hole for the perk test. Just to get the permit, hire a hoe to dig the hole and do the perk test will run a $1,000 before you ever get started on the septic system.
I think you're in for a surprise on the cost. How to set up WiFi is the least of your problems.
Bill
