rdhetrick's avatar
rdhetrick
Permanent Site - 12v Efficiency
Hi all,
I have a permanent site where I have a 5th wheel set up. My question revolves around the 12v system.
I know the factory converter/charger is horrible as far as a charger, but I'm thinking efficiency on two scenarios:
1. Disconnect the battery and use the existing converter to power all the 12v needs.
2. Disconnect the converter/charger unit and use a standalone charger to maintain the battery, and power all the 12v from the battery.
I guess this comes down to how efficiently the factory converter converts 120v to 12v versus how efficienty a smart charger can convert the 120v to 12v.
The fist scenario is very simple, no battery maintenance to worry about. I'm interested in exploring this as I am starting to gear up towards boondocking in the future.
Any comments are appreciated.
Thanks!
Rob
  • 1 is almost the best answer. The battery may need to be inline for things to work. Slides ETC. Give it a try by disconnecting negative side of battery
