riven1950
Sep 05, 2018Explorer
I would cut off water at the street ( whole house ) if possible. I have found turning water off at a toilet, especially if plumbing has some age, will cause the cutoff valve to leak either when off or when you cut it back on. If you have newer valves or new washers in old valves it should not be a problem.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
