Nmyarger's avatar
Nmyarger
Protecting slide-out awnings from snow load
I'm concerned with the potential damage to the slide out awnings from too much snow. I can't afford to build a structure over my 5th. Does anyone know of an inexpensive solution or have experience with this type of thing? I don't think the beach ball idea will work in the wintertime.
Im a newly single 57 year old woman with limited income. Living in my 5th in Michigan year round is going to be a new experience. My Jayco has the Polar Package, but I'm hearing that it makes little to no difference. I'm all skirted with T1-11 and 2" r-10 foam insulation. Heat tape on water pipes. So far from these forums I've learned that I should also wrap my (hard-not flex) sewer pipes, and I plan to install either the bubble wrap or the transparent plastic on the windows. I'll have a well pump heater underneath and possibly one in utility area.
With everything I've said, does anyone have any more advise for me? I'm really nervous about this. My 5th is beautiful and I don't wanna make the inside icky or ugly or anything. Lol. Sounds silly, but I like pretty stuff.
I'm also nicely equipped (please God, make it true) to keep out the mice/spiders... using peppermint essential oils EVERYWHERE.
THANK YOU TO ANYONE WHO RESPONDS.
  • Since it won't snow every day you might just want to pull in the slides when snow is expected and put them back out when the storm is over. It will also keep you a bit warmer during that period. Be sure you have plenty of propane as mentioned above!
  • Why won’t the beach ball idea work? Has for others as Joe says. Watch for condensation problems.
  • Go to Walmart or a dollar store and buy small beach type balls that will roll under the covers...2 or 3 balls depending on length of slide...that will keep the fabric from sagging or stretching due to weight of snow...usually a 4" or 5" ball will work
  • If you haven't already, contact a local propane supplier about a large tank that they will come to you and fill, it's usually cheaper than going to a hardware store or similar location and you will likely be using a lot.
