down_home
May 20, 2017Explorer II
Be sure to have surge protector and brown out protection installed.
A building even a gazabo. Sams has a large one for 1200 or so. Wall it if you desire and have a building. Wire it for electricity. Put the water filter/ softener if need be in one corner.
If you us concrete dye it and have a pattern put into it or put large tile in the patio area. Keep it all the same grade or level.
Make sure the tower for power, cable tv, water etc is on the pad and not the ground.
Plantings and water features really make one of these. Built in pellet grill or other. The RVer won't have to haul his out to grill.
Water faucet so RVer can wash his car or the Mh, filtered of course .....and fittings and timer and control to provide water for sprinkler system for lawn area.
on edit. I understand your idea of a cover for thee pad. I've seen many in west Texas and else where. The sun is brutal and hot.
It's a good idea. About the Satellite dish usage under a cover.... well, if the pad is situated just right, a large enough section of roof that opens, sides perhaps in rails or other, would allow use of their Satellite.There are all sorts of workable ideas, just depends on what you want to do and energy to carry through with it.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
