I_am_still_wayn
May 31, 2013Explorer
duncanwoods wrote:
The ac in the ceiling has nobs for low fan, high fan, low ac, and high ac. There is a dial for the temperature which I guess is technically a thermostat, I was thinking of the kind with temps on it. Is it bad to run the ac all the time?
Turn the knob to either low ac or high ac your choice. Turn the temperature knob about half way of its travel. Turn to to colder if you are then hot or warmer if you are then cold. The fan will run constantly, but the compressor (the thing that makes cold air) will turn off and on to maintain whatever temperature you set with that temperature knob. It will not hurt it one bit to run all the time. Actually, running the unit is better than not running it!
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
