duncanwoods
May 31, 2013Explorer
doxiemom11 wrote:
I don't know why your AC isn't on a thermostat? Is your thermostat non-functional? Maybe some simple repairs could take care of that so you could set it for a temp and leave it on.
As far as the bed, is the base of the bed level (platform). If so, then sounds like you need a new mattress along with that topper (HOPE YOU BOUGHT A GOOD QUALITY TOPPER AS THE CHEAP ONES AR HOT TO SLEEP ON). If the platform isn't level, then you better find out why - is the floor under it sloped and why.
THANK YOU for your suggestion to check the platform with a level!!! That is our problem, at least for now! We will be adding to the support very soon to level it out. Thanks, thanks, thanks!
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
