- hmknightncExplorerNot sure of your exact conditions but I have an 18k tri-axle horse trailer with 100,000 miles on it. Brakes on inspection last year showed about 50%. Brake wear on trailers is simply something I don't worry about. They do get check for mechanical condition every year during bearing greasing.
- kaydeejayExplorer
[email protected] wrote:
While this will work for disk brakes, the drum needs to be removed to check the linings of drum brakes
You can often look thru the slot in the wheel with a bright light to view the pads. - usmohls2ExplorerYou can often look thru the slot in the wheel with a bright light to view the pads.
- powderman426ExplorerIf its been more than a year since you looked, its probably a good idea to pull them and look and you can grease the bearings at the same time. Also just because one looks good does not mean that its not necessary to pull and look at them all as one could be worn more due to drag or sometimes the lining will come loose.
- popeyemthExplorerSorry,no.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
