- RVcrazyExplorerConsider a used Nuwa Hitchhiker fiver. We have been FT in ours for the past year :-)
- Cummins12V98Explorer III"Most of us just keep getting bigger and bigger"
So true!!!
24', 28.5', 32.5', 36' and now 39.5' does this madness ever end??????? - rdthompson1ExplorerA couple mentioned is a good place to start. Mobile suites is excellent and Open Range. You need to give more details to get a good answer. How much do you want to spend? What are you going to pull it with? What is available to you where you can reasonably get it and get repairs to it? MOST full timers want lots of room, especially storage. Some can get by with less than 30 feet. Whatever you get you will probably have for much less time than you plan. Try to get it right the first time. Most of us just keep getting bigger and bigger. That's just a hint.
- billy79ExplorerIf you find a rig you like contact the manufacturer and ask if living in it full time voids the warranty. You would be amazed how many Fifth Wheels and TT's (not sure about motorhomes) will void the warranty if you live in it full time.
Any rig that won't stand behind their warranty if you live in it full time is probably not one you want to live full time in. - sushidogExplorerI didn't know DRV made a TT, just Fivers. It must have been some time ago. I do like DRVs though as they are very sturdily built, but they do require a substantial TV.
Chip - missourijanExplorerDrv, we've owned 2 and would buy another
- sushidogExplorerThe most common limiting factors you will find in finding a TT suitable to FT in are:
1. Not enough carrying capacity (low CCC) - Most FTing couples recommend 3,000lbs and up. Finding storage space to put 3,000 lbs of gear is a limiting factor too.
2. Poor insulation - look for upgraded insulation packages with thermal foil. heated holding tanks, an insulated compartment for valves, and double pane windows if possible.
3. Weight (and possibly tongue wt.) will be a limiting factor also, depending on what kind of TV you have. For a TT I recommend no less than a 3/4 ton, and a diesel if you can afford it.
If money is no object there are custom TT manufacturers, like Spacecraft, but their units are pricy even used, and some are very heavy, requiring a huge TV.
http://www.spacecraftmfg.com/
If you are looking for something more affordable I would recommend the Highland Ridge Open Range models http://www.highlandridgerv.com/journeyer/floorplans.php
I also like the Keystone Sprinter line for more affordable, yet decent quality trailers. http://www.highlandridgerv.com/journeyer/floorplans.php
Be sure and look at toy haulers too. I like the Work and Play line by Forest River as they are lighter, have good carrying capacities and a metal roof that won't need replacing every 12-20 years like EDPM roofs do. Here's my favorite model, the 36FKBS with a center bedroom and 2 slides, though it is a little on the heavy side, it is well made. http://www.dreamchasersrv.com/rv/WORK-AND-PLAY-36FKBS-TH0015241
Chip - C-BearsExplorer
mikensallyt wrote:
That's an easy question. All of them are IMHO
That is probably the most accurate answer you will get on this forum from us "experts".
Suggestions from someone that you shouldn't get anything with a rubber roof for full time use because they are not quality RV's is just a small example of the goofy statements that will flow through this topic.
There are a lot of full timers out there in everything from 20 year old TT's to $1,000,000 MH's and everything in between. - Cummins12V98Explorer III"If it has a rubber roof, keep looking as it's not a quality rig" Not always true.
New 39TKSB3 Mobile Suites. I chose not to get the Fiberglass roof. Too many problems and the warranty was not even close to the rubber. - IvylogExplorer III
sdianel wrote:
Foretravel, Newell, Newmar, Country Coach, Entegra, American Coach, Tiffin.
Did not know all of these manufactures made trailers????
If it has a rubber roof, keep looking as it's not a quality rig.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
