nancyjerry's avatar
nancyjerry
What are you using for external water filtration?
Due to a recent freeze while we were away, the filtration system in our bay got destroyed...
Looking to use an external one now and probably under sink.
As full timers moving to unknown water systems all the time, what are your recommendations?
  • philh wrote:
    TechWriter wrote:
    Plus, you can plumb an RO system so that the waste water goes back into your water tank so there's no waste.
    no issues with the "dirty" water going back into the tank?
    Not really. RO systems have multiple stages: typically 2 or 3 filters (sediment, carbon block, etc), then the RO membrane itself, and finally post filters like "water polishing" or adding minerals.
    The waste water or brine comes from the RO membrane so the water has already passed through filtration that most RVers use anyway.
    If anything, the RO brine is hard water, not "dirty". TDS (Total Dissolved Solids) levels in ppm are usually used to measure RO system water quality. For example, one of my measurements was . . .
    - "Fresh" (incoming) water: 242 ppm
    - RO treated water: 34 ppm
    - RO Brine: 202 ppm
  • CA Traveler wrote:
    Returning the unfiltered RO waste drinking water to the tank adds to the tanks contaminates which increases as the tank empties. So increased filter replacement.
    Depends where you put your RO pre-filters. Mine filtered water before, not after, the water hits the holding tank. So no strain on the filters.
  • I run off my tanks exclusivly. A 10 Micron sediment filter, then a 5 micron sediment filter, then a 5 micron carbon filter, then a 100 gallon/day RO membrane.
    In New Orleans I have 300 + PPM TDS in, 12 PPM out.
