pigman1
Jul 14, 2020Explorer
Fisherman wrote:You do know you'll have to change ferries at either Skagway or Haines, right? The ferry from Bellingham north does not keep you out of Canada. You'll be in Yukon Territory, Canada at the Haines Junction road or just below Whitehorse. Don't know what those crossings are doing. The ferry from Haines or Skagway across the Gulf of Alaska to Valdez or Whittier makes it a very expensive trip. You'll need a cabin and meals all the way and won't be able to access your RV except at certain stops and the LP MUST be turned off and sealed before loading.
Put your RV on a ferry and go by water, the last thing we need up here is an increase in cooties. Essential should be work only and then by aircraft not stopping here.
About International Travel
86 PostsLatest Activity: Jul 24, 2025
