luberhillExplorerAug 22, 2017? help on 2005 28ft Gulf Stream class CIt has 51k miles,,,no leaks, needs 4 rear tires, everything seems to work except the coach ac doesn't seem to blow much out of the ducted vents, if you open the grate on the unit itself it pours out a...Show More
Chris_BryantExplorer IIAug 22, 2017Duct problems are fairly common- a bit of time with a flashlight, mirror and some foil tape will work wonders.
Related ContentStreamingfree streaming videoXfinity streamStreaming and BlackoutsStreaming Amazon videos?
