Chris_Bryant
Aug 22, 2017Explorer II
luberhill wrote:Chris Bryant wrote:
Duct problems are fairly common- a bit of time with a flashlight, mirror and some foil tape will work wonders.
Pls explain what to do
Basically, remove the vents, stick a flashlight at one end, use a mirror at the other end to check for obstructions, them look at gaps between the vent and duct- seal any of those, then drop the ceiling assembly cover and look at the duct connections, seal those. Last, make sure the divider between the return and supply air is sealed.
There have been a couple of threads about this- some with good pictures, but I cannot find them.
38,771 PostsLatest Activity: Apr 15, 2026
