youracman
May 28, 2019Explorer
Jayco-noslide wrote:
We have a 2003 30 ft. Winnebago Class C with 35000 miles. We like it and it currently serves our needs. Right now it's in a shop getting a whole list of things done to fix or prevent more problems. The estimate is $2,400 to $3000. I'm not shocked at all but how much would you spend to service and repair your present unit. If we traded we would downsize but would just have to find another 5 years old or more and with some miles.
In reading several forums over about 5 years, I have read where some "seasoned" owners have stated they planned for $3500 per year repair/maintenance expenses with their DP's; one guy had owned both and stated his gas Class A ran about 1/2 that. They did their own routine maintenance. I do mostly all my own work on my Class C and it runs a bit less than than their estimates for Class A's. I do note that some folks say there seems to be a maintenance "spike" at about 10 years of age...... that squares with my experience; e.g. new rooftop AC at 10 years (self installed) and new front brakes at 11 years and 50K miles (self installed.)
I note your coach is w/o slide so that will work in your favor; although in 12 years my only slide expense has been for dry lube spray cans (which I use religiously) and a new slide topper. I consider myself lucky in the slide department. :^)
Obviously one can estimate the average, but the amount of + or - around the mean will be dependent on a lot of factors (and it will probably be a pretty big number.)
Then there's the rate of depreciation........ ouch.
Safe travels..............
