youracman
Jun 09, 2019Explorer
tobydad wrote:
No luck at any salvage yards. E-mail from Winnebago - do not have the encoders (actuators) and cannot get them nor manufacture them. Repair facility in discussions with Lippert was advised to by-pass the encoders and wire the motors directly with new switches for each motor.
Be interesting to hear what others have to say. Intuition tells me that'll work. I would like to be observing an ammeter on each motor right there at your new double switch panel......just for grins. Does seem like if one motor got overloaded the Hall Effect device would shut it down (like it does when you hit the stops) and you could regroup? Interesting for sure.
Once the mod is done, seems like you could just stop the slide travel at several intervals and measure the travel on each side.......to get to know the system and how to "drive it with the switches" so to speak.
Sure hope you post back on this fix. Good possibility many of us will be in a like position sooner or later and you will be plowing new ground for sure.
Best.............
