MountainAir05 wrote:
One is going to be the Antenna, The other one could be a Cable/sat line if you have sat. The other one the TV.
Power on the box and try each cable to the TV.
Or you can jump out the one line at the cable back in the electric door and ohm it out inside the RV. That will give you one.
As stated one is TV antenna, but knowing which the other two does not take too much time to figure it out.
Hi and thanks for the help. I did locate which inputs are the antenna and the bedroom tv following your suggestion. The tv in the bedroom is #2 and goes in the Jack on the far right. The antenna is in the input on the far left. I’m waiting for the living area tv to show up so I can check the middle input and the front input.
kp
