Makin__Do
Jan 04, 2016Explorer
Thanks for all your input. Was really hoping someone had already set up a system on a Pleasure Way Excel wide body. That doesn't seem to be the case so far. However, a roof is a roof and you only have so much area that you can attach panels to. In my case two would be the max.
Now, which panels and which controller questions would be best posted in the Tech forum.
What I'm setting up is a second and separate battery system. The current factory system has room for one 12v group 34 battery in the outside compartment for all house needs. It's an almost new battery, so I don't want to replace it. My second system will have two Lifeline 6v batteries at 220 AH that will provide for only an Engel DC front opening fridge and when needed, power for a PlatCat catalytic heater. Both batteries will fit under the sink. I do not have nor do I want an inverter.
38,783 PostsLatest Activity: Sep 23, 2026
