rgatijnet1
May 28, 2015Explorer III
The P chassis is 103" and the W chassis is 108.5". There is only one belt for everything. Be sure to check out BOTH of your idler pulleys for bearing wear. All it takes is a 3/8" breaker bar to take tension off of the belt to change it. Be sure to have a routing diagram with you to replace the belt as it will only go on with one configuration.
38,769 PostsLatest Activity: Mar 31, 2026
