Southwind98 wrote:
I would hope gluing wouldn't have been the case by Fleetwood. When I removed the lid on my doghouse the seal was very tight, as it should be. Took two flat head screw drivers and applied force on opposite sides of the lid, using the frame to push straight up. Or use something like a hook and put in the screw holes and pull straight up. Good luck
I am not talking about the access panel on top of doghouse but the whole doghouse, I have came to the conclusion that this doghouse was not meant to be removed easy, got what I needed done without removing it, sure hope when it's time to replace spark plugs they can be done without doghouse removal.
