jarviswin
Oct 30, 2014Explorer
I am not surprised. I bought an 06 Aspect (24 ft). Guess what I found when I took the TV out? 75% of the brackets had the bolts off. 2 were a royal pain cus where they were located. I put lock washers and nylon nuts on all I could. Thought I took care of the squeak. Wrong, still got one somewhere. I noticed that the brackets are riveted in thru the roof. Will check to make sure they are all tight.
You state there was a bracket(s) between the cab roof and the plywood that the TV sits on, or they the brackets on the side opening?
38,766 PostsLatest Activity: Jan 10, 2026
