- spotrotExplorerThank you all. Excellent suggestions about things to check.
I assume the control module would draw less than 0.10 amp - BrianinMichiganExplorerRan into a jammed CD on a radio that would kill the battery in a day or 2. The unit was trying to eject the CD but you couldn't hear it.
- IF the 2020 Ford dash has the standard Headlamp switch with the roll wheel Dimmer----IF that wheel is rolled to the click position(normally turning on the overhead light, NOT installed on most Chassis), that engages a relay. Even with NO light connected it will cause a drain from that relay. Also some RV makers install a light to that switch, but that light is in front above the radiator and not easily seen if on unless at night. Doug
- herbert007ExplorerI have 2006 Winnibego Ford V10. I had a draw on my battery to the point it would be dead after a week camping. It turned out the alternator was bad and drawing down from the battery.
