rgatijnet1
Jun 14, 2013Explorer III
Terry,
It sounds like you have some bad electrical connections from corroded wires/connections. These are usually ground connections, but can also be on the 12 volt positive side. The bad connection can sometimes be behind the dash where the dash meters are connected to ground which is causing them to be erratic.
38,771 PostsLatest Activity: Apr 13, 2026
