homerbw
Oct 17, 2013Explorer
12 volt fuse
I have a small problem that needs some advice. Recently my jacks (HWC) would not retract because no power was going to the switch. I opened the 12 volt fuse box under the dash to try and troubleshoo...
homerbw wrote:
I have a small problem that needs some advice. Recently my jacks (HWC) would not retract because no power was going to the switch. I opened the 12 volt fuse box under the dash to try and troubleshoot the issue. When I removed the fuse box cover, a 5 amp fuse dropped to the floor. Ah, Ha, there is the problem. Nope, it was something else, not the wayward fuse. I need to know where the fuse goes in the fuse box but there is nothing in my owners manual or on the fuse cover which tells me. Is there another way for me to fine out?
