I have a small problem that needs some advice. Recently my jacks (HWC) would not retract because no power was going to the switch. I opened the 12 volt fuse box under the dash to try and troubleshoo...
Are your jacks working yet? Check all the open fuse locations for those that have two metal connectors in them. Usually manufacturers will only put in the connectors for the items they use and end up leaving one side of the fuse location with a metal connector and the other side just a blank.
