I have a small problem that needs some advice. Recently my jacks (HWC) would not retract because no power was going to the switch. I opened the 12 volt fuse box under the dash to try and troubleshoo...
The jacks are working. They were not getting power through the starter switch even though the engine and everything else was working. I turned off the engine and when I restarted it, the power came on for the jacks. A thought came into mind, what if I used a light tester to jump one side of the fuse holder to the other side? Would that indicate power to a fuse location or cause a short?
