homerbw
Oct 17, 2013Explorer
12 volt fuse
I have a small problem that needs some advice. Recently my jacks (HWC) would not retract because no power was going to the switch. I opened the 12 volt fuse box under the dash to try and troubleshoo...
homerbw wrote:
The jacks are working. They were not getting power through the starter switch even though the engine and everything else was working. I turned off the engine and when I restarted it, the power came on for the jacks. A thought came into mind, what if I used a light tester to jump one side of the fuse holder to the other side? Would that indicate power to a fuse location or cause a short?
