wa8yxm
Jan 03, 2021Explorer III
I have not heard of that in a long,,,, long...... long time (like 1970s)
I used to have a plug that contained just two parts. in fact I still do. One was a 2-lead tri-color LED and the other was a resistor..
IF you plugged it into a 12 volt accessory outlet that was properly wired GREEN
If you plugged it into one that was reverse wired RED
If it showed yellow.. Well that outlet had AC on it not DC (never happened)
This can be done with a volt meter.. I suggest a plug to binding posts for this.
but you can do it without
Using adapter Like this one hook meter black to black red to red and plug in read voltage
+13.6 (ending running) or 12.6 (Engine off) = Good
Negative voltage or 15+ volts = bad
Without the adapter it's a touch tricky
Black to SHELL and red to the center of the bottom of the outlet
That adapter however is how I'd do it
Side benefit. If you ever have to replace the plug on a 12 volt cord (just the plug not a plug/voltage converter like for your phone et-al) well this is real handy for that. Till you can get a proper crimp or solder on plug.
38,782 PostsLatest Activity: Aug 31, 2026
