Bugman114
Aug 08, 2014Explorer
I had just replaced the two house batteries, and checked them. They are at about 13.2 volts with everything off (it has an on board battery charger), and they both load tested fine (disconnected them and tested individually) with an actual load tester (the one with the heating element inside).
I'll check out the converter, and let yall know what I have. Thanks for the info! :)
I should also mention that I have been driving my MH to work everyday, because both my cars broke down at the same time, lol. I have installed a 100 amp alternator which charges both the house, and starting batteries (i assume that's what the isolator is for, but now that I mention it, I wonder if it's capable of handling 100 amps).
38,783 PostsLatest Activity: Sep 23, 2026
