Tinstar
Sep 21, 2017Explorer
12 volt to 120 volt ground
I've got a 12-volt light above the passenger seat that does not have a good ground. The positive side of the light is getting good voltage and it works when I manually ground it. I removed the light and the negative is no good coming to the fixture. I pulled the bottom out of that cabinet thinking the problem was there and it would be an easy fix. As my luck would have it, the wire disappears into an inaccessible cabinet toward the front AND there is NO other ground in there to tie the fixture. I do have easy access to a 120-volt plug. Is there a problem of supplying the 12 volt light fixture from the ground of the 120-volt plug? I know it will work but would there be any negative effects to permanently wiring it like that. I really don't want to start tearing out cabinets.
