dougrainer wrote:
Mandalay Parr wrote:
I would Not connect those two grounds together. For 12 volt ground I would use the chassis if you can not find the ground wire.
Where do you think the 120 Ground circuit has its final ground? AT the chassis frame. What do you think could possibly be a problem with using the 120 ground for a 12 volt light? Nothing! Doug
I've seen cases on other equipment where someone connected the grounds together and shorted out the rectifier. Not sure if a MH converter would do the same but why take a chance.
Also the ac neutral is not to be bonded to the chassis ground in an rv.
Jerry Parr
