2oldman wrote:
You mean you have to change the TV because it's coax? Jensen is not popular.. it's junk.
You could use a small inverter fed by the 12v and then have your choice of TVs, not 12v trucker stuff.
The TV in the bedroom right now is fed by a coax cable. it is connected to the multiple tv selector at the front of the coach. That selector only
has coax in and coax out. The direct TV box has coax in and HDMI out. So like i asked in a previous post how do you convert from HDMI to
coax? You can for 500 bucks with some hi tech box OR you can run new HDMI, get a HDMI splitter and plug it into the back of the direct TV
receiver. Direct does not offer receivers anymore with coax in and coax out. They offer them with coax in and HDMI out. That's what they told
me yesterday. As your components start needing replacement ya'all are going to be facing this issue me thinks.
OK, back to the rear tv. I can take the 12volt that is existing, plug it into an inverter, plug tv into inverter and screw the 12 volt tv?
Man that opened up a lot of options. As far as tv's for the home not suitable to the movement experienced by the motorhome, true or false?
