I have a light switch that has 2 prongs on the backside, and both have an orange wire to it. How do I determine which is the Hot side and which is the switched side? Or is one Hot and the other Grou...
I'm assuming you're using this "hot" as your feed for the slide relay..:h. Put in simple terms, a switch simply breaks a hot lead into two parts. One side will always be hot, the other side "cold" until the switch is thrown, at which point the wires will be connected and therefore both hot. On a two prong switch there is no ground.....Dennis
