VA-Apraisr
Mar 08, 2020Explorer II
When my AGM's finally give out, I'm going with one Lithium battery. Read some great information on Battle Born lithium website. Only weighs about 30lbs and can be discharged down to 0% without hurting the unit. Just plain tired of watching the voltage meter on the wall and when it gets close to 11 volts, having to start the generator or engine. I dry camp most of the time and although this one battery costs about $1,000, seems like the life span is way more than what I've seen out of my AGM units. Can drain to nothing at least 3000 times and still the battery will perform at 80% after that. It's worth looking into before putting out $450 for 2 heavy AGM's that weight about 80lbs each.
