Bigcheezuz's avatar
Bigcheezuz
12v house battery replacement
I haven't seen this asked anywhere.
So I am looking to replace my house batteries and wanted to know what would be the best replacement for full time living. I've seen that they range from $350ish-$4000 I don't really want to sell a kidney but if it's for the best then so be it
Any suggestions and or opinions are greatly appreciated
Edit: I'm new to forums and also full time rving
Edit 2: I have a thor chataeu 24fs with an extra auxiliary battery and I'm not sure what the stock batteries brand is
  • For fulltime use when you are almost always in a campground with electric service?
    For fulltime use when you mostly boondock/dry camp? If this is the box you check, have you completed an energy survey to determine your battery size (amp hour) need?
  • If you can swing the initial higher price AGM's will give the best performance/bang for the buck. Whether or not you choose to go 12 volt or 6 volt golf carts will probably be determined by how much room your existing battery bay has as GC's are taller.
    There is no such thing as a maintenance free battery but the routine servicing of AGM's is a lot easier, less to do. I got two pure deep cycle Group 27 AGM's at Batteries Plus for a little under $400 a year or so ago and that was the best deal I could find on line or over the counter.
    Good luck.
    :C
