tatest
Dec 28, 2013Explorer II
You will not likely add that much wheel size without a significant increase in overall diameter, so mesure clearances to see if the coach builder left enough room for a larger wheel/tire.
Bolt circle, centering hole might not be compatible with modern F-550, so check that carefully. There might be a 19.5, and maybe a 17.5 replacement wheel, but not necessarily from a more recent F-series.
