Ok awesome thank you! I’m sure it will be easy to find, I just couldn’t find the shut off last time I was there but also didn’t look very hard. Trying to get as much info lined up before I get there at the end of the month so I can spend more time working on it, and less time figuring out how to work on it.
Aside for the obvious mechanical checklist, anything I should do/check before I take her on the long voyage home and a little camping adventure?
Already plan on doing spark plugs, oil/air filters, change the oil, exhaust manifold gasket.... the septic tank was winterized by the previous owner. Can I just proceed to use it now that it’s not winter, or are there shut off somewhere that need to be turned on? I imagine the water connection to the toilet may be off, everything else should be good to go?
Thank you!
