SRT
Jan 05, 2014Explorer
BelleStarr71 wrote:
Primary tank was full.We think it may have went bad as it sat. He says engine purrs when it is running. But, it has backfired. Maybe you are right. I will pass your suggestions to my husband. Thanks.
The bad smell is usually indicating old gas. If you can I'd get rid of about a half tank of the current gasoline and fill it up with new gas. Probably a good idea to change the fuel filter and put Seafoam additive in the tank when you fill it. You'll have to change the fuel filter again after a tank full has been run through.
Good luck.
38,769 PostsLatest Activity: Apr 03, 2026
