2bzy2c
Jan 05, 2014Explorer II
Born To Travel wrote:
Another thing those late 70s Mopars were famous for was the ballast resistors going bad.. On the firewall will be a rectangular white ceramic looking thing with a plug on each end.. these acted like a fuse for the ignition system.. When they went bad it would not start.. Back then everyone carried a spare in the glovebox.. To test it unplug both ends and take a ohm meter and check the lower one from end to end and the upper one from end to end.. If either reads open then it is bad.. One side is the start circuit and the other side is the run circuit..
So true. I was going to write about that, but felt I was not able to give a good description of it. Back in the day, I drove a tow truck for auto club. I always carried one. Came in handy more than once.
However, the resistor will have nothing to do with the backfiring. Just the starting.
38,769 PostsLatest Activity: Apr 03, 2026
