Depending on how long it has been setting, you may be for a lot of junk in the gas tank, rust and dirt as well as varnish gas. I would try getting it running with an auxiliary gas tank with filter and hose directly to the fuel pump, If you get it running that way, then try siphoning the tank and put a little fresh gas in there and siphon it again, or pump it toward the front but not into the carb. The dirt and varnish will be some of your biggest problem in getting it running and moving. You night even consider a marine tank just to get it home, although safety is an issue. brakes will also be a primary consideration for your trip home. Keep us posted and best of luck on the trip and the restore, should be a neat one. Happy Trails Bert
