shaneperch wrote:
I wish I could fit a DT466 in there. that would be the bomb. But I read on an old brochure that this motorhome is built on a steel cage wall with fiberglass skin. So according to the travco website I recently found stated that the AVCO is built out of steel and fiberglass COOL COOL COOL!!!! no wood in the walls. I will crawl under it tomorrow. I hope that generator starts. Does it have to have a certain amount of fuel in the tank before it runs? Thanks again.
Yes, if it is like most rigs, there must be at least 1/4 tank of gas for the generator to start and run. Be sure to check the fuel hoses to the generator. The rubber may have deteriorated, and the fuel pump will suck air instead of fuel. If such is the case, the generator will not run. Yeah, been there, did that, 1977 Pace Arrow, dodge 440.
Good luck.
